Option to hide "Sending Message" dialogue box?
How can I set options so that the "Sending Message" dialogue box does not appear?
If that is not possible, how can I immediately continue with processing my emails without waiting for the popup to disappear? It seems that I can type Cntl+Shft+Enter (instead of Cntl+Enter) to put my outgoing email in the Outbox, but how do I set an option for the Outbox to be emptied every minute or so?
See http://kb.mozillazine.org/Thunderbird_3.0_-_New_Features_and_Changes#Send_in_Background
Options/General/Indexing/Config. editor.
Thanks for the tip, sfhowes.
Default: mailnews.sendInBackground preference set to false and mailnews.show_send_progress to true is the default setting. It shows a popup with progress after Cntl+Enter. At this point Alt+Tab will bring you immediately to the Thunderbird main window.
Progress in footer: mailnews.sendInBackground false, mailnews.show_send_progress false -- no popup, but message stays in foreground (temporarily while being sent) with progress in footer of message. At this point Alt+Tab will bring you immediately to the Thunderbird main window.
To Outbox: With mailnews.sendInBackground preference set to true and mailnews.show_send_progress to false the message is immediately sent to the Outbox, but processed no further, i.e. not sent later.
To Outbox: mailnews.sendInBackground true, mailnews.show_send_progress true -- the message is immediately sent to the Outbox, but processed no further, i.e. not sent later.
Gewysig op
